Infineon IR2114/IR2214电源开关应用的半桥栅极驱动器解决方案关键词:电源管理栅极驱动器 Infineon IR2114/IR2214
时间:2021-7-30 17:09:21 来源:中电网
Infineon公司的IR2114/IR2214是用来驱动功率开关应用的单个半桥栅极驱动器,提供高的驱动能里(2A源,3A沉),具有低的静态电流,这就允许在中等电源系统中使用升压电源技术.通过功率晶体管去饱和检测和通过专用的软关断引脚来平滑关断去饱和晶体管栅极驱动器,因此器件具有短路保护功能,因而防止出现过压现象,降低了电磁发射.在多相位系统,IR2114/IR2214驱动器采用专用的本地网络(SY_FLT 和FAULT/SD信号)来适当地管理相位到相位的短路.为
Infineon公司的IR2114/IR2214是用来驱动功率开关应用的单个半桥栅极驱动器,提供高的驱动能里(2A源,3A沉),具有低的静态电流,这就允许在中等电源系统中使用升压电源技术.通过功率晶体管去饱和检测和通过专用的软关断引脚来平滑关断去饱和晶体管栅极驱动器,因此器件具有短路保护功能,因而防止出现过压现象,降低了电磁发射.在多相位系统,IR2114/IR2214驱动器采用专用的本地网络(SY_FLT 和FAULT/SD信号)来适当地管理相位到相位的短路.为了改善DC总线噪音的信号免疫力,控制和电源地采用专用引脚,使得低边发射极电流检测也一样好.浮动时的欠压条件和低压电路是单独管理的.浮动通路高达600V或1200V,过流时软关断,集成了去饱和检测电路,两级的开输出用来di/dt控制,单独的上拉/下拉输出驱动引脚,匹配的延迟输出,具有滞后带的欠压锁住和无铅产品.主要用在HVAC,HVAC泵,HVAC通风,工业自动化,工业马达驱动和控制.本文介绍了IR2114/IR2214主要特性和指标,典型连接图,功能框图以及1200V结隔离栅极驱动器IR2214SS评估板EVAL-M1-IR2214主要特性和指标,电路图,材料清单和PCB设计图.
The IR2114/IR2214 gate driver family is suited to drive a single half bridge inpower switching applications. These drivers provide high gate drivingcapability (2 A source, 3 A sink) and require low quiescent current, whichallows the use of bootstrap power supply techniques in medium powersystems. These drivers feature full short circuit protection by means of powertransistor desaturation detection and manage all half-bridge faults by
smoothly turning off the desaturated transistor through the dedicated softshutdown pin, therefore preventing over-voltages and reducingelectromagnetic emissions. In multi-phase systems, the IR2114/IR2214drivers communicate using a dedicated local network (SY_FLT andFAULT/SD signals) to properly manage phase-to-phase short circuits. Thesystem controller may force shutdown or read device fault state through the
3.3 V compatible CMOS I/O pin (FAULT/SD). To improve the signal immunityfrom DC-bus noise, the control and power ground use dedicated pinsenabling low-side emitter current sensing as well. Undervoltage conditions ...
