Intel Cyclone 10 LP FPGA系列评估方案
关键词:Cyclone 10 LP FPGA工业自动化有线和无线通信医疗电子消费类电子 Intel
时间:2021-8-2 16:37:17      来源:中电网
Intel公司的Cyclone 10 LP FPGA系列是高密度海量可编门,板上资源和通用I/O的器件,具有低成本和低静态功耗,非常适合用在量大和成本敏感的应用如工业和自动化,广播,有线和无线通信,计算和存储,政府,军队和航空航天以及医疗,消费类电子和智能能量等领域.器件采用低成本低功耗的FPGA架构,1.0V和1.2V核电压选择,可选择商用,工业和汽车工作温度.器件的核架构采用逻辑单元(LE)-四输入查找表(LUT)和寄存器,所有LE间丰富的路经/金属互连.器件
Intel公司的Cyclone 10 LP FPGA系列是高密度海量可编门,板上资源和通用I/O的器件,具有低成本和低静态功耗,非常适合用在量大和成本敏感的应用如工业和自动化,广播,有线和无线通信,计算和存储,政府,军队和航空航天以及医疗,消费类电子和智能能量等领域.器件采用低成本低功耗的FPGA架构,1.0V和1.2V核电压选择,可选择商用,工业和汽车工作温度.器件的核架构采用逻辑单元(LE)-四输入查找表(LUT)和寄存器,所有LE间丰富的路经/金属互连.器件存储器区块有可级联的M9K-9Kb嵌入SRAM存储器区块和可配置成RAM(单端,简单双端和真正双端),FIFO缓冲器或ROM.嵌入的乘法器区块有可级联的一个18x18或两个9x9乘法器模式,以及用于算法加速的全套DSP IP.时钟网络包括驱动整个器件的全局时钟,和能驱动多达20个全局时钟的15个专用时钟引脚.有多达4个通用PLL,提供鲁棒的时钟管理和同步.本文介绍了Cyclone 10 LP FPGA主要特性,LE框图以及Intel® Cyclone® 10 LP FPGA系列评估板主要特性,框图,主要元件和电路图,材料清单.
The Intel® Intel Cyclone® 10 LP FPGAs are optimized for low cost and low static
power, making them ideal for high-volume and cost-sensitive applications.
Intel Cyclone 10 LP devices provide a high density sea of programmable gates, onboard
resources, and general purpose I/Os. These resources satisfies therequirements of I/O expansion and chip-to-chip interfacing. The Intel Cyclone 10 LParchitecture suits smart and connected end applications across many marketsegments:
• Industrial and automotive
• Broadcast, wireline, and wireless
• Compute and storage
• Government, military, and aerospace
• Medical, consumer, and smart energy
The free but powerful Intel Quartus® Prime Lite Edition software suite of design toolsmeets the requirements of several classes of users:
• Existing FPGA designers
• Embedded designers using the FPGA with Nios® II processor
• Students and hobbyists who are new to FPGA
Advanced users who require access to the full IP Base Suite can s...
