[原创] ST SPC560P50L5 32位系统级(SoC)芯片汽车应用方案
关键词:Power Architecture MCU 系统级(SoC)芯片 汽车电子 SPC560P50L5
时间:2018-08-06 10:56:27       作者:ST       来源:中电网
ST公司的SPC560P50L5是基于32位Power Architecture®的MCU,集成了1088KB闪存和80KB RAM,满足AEC-Q10x规范,工作频率64MHz,提供高性能处理性能而又低功耗,具有可变长度编码(VLE),Nexus® L2+接口,单电源3.3V或5V用于I/O和ADC,工作温度–40到125℃或–40到 105℃,主要用在汽车底盘和安全应用.本文介绍了SPC560P50L5主要特性,框图,以及SPC560P-DISP Discovery开发板主要特性,电路图和材料清单与PCB设计图.
32-bit Power Architecture® based MCU with 1088KB Flash memory and 80KB RAM for automotive chassis and safety applications This 32-bit system-on-chip (SoC) automotive microcontroller family is the latest achievement in integrated automotive application controllers. It belongs to an expanding range of automotive-focused products designed to address chassis applications specifically the airbag application.
This family is one of a series of next-generation integrated automotive microcontrollers based on the Power Architecture technology.
查看全文
