Freescale PF0200 12路可配置电源管理解决方案
关键词:电源管理 PMIC DC/DC转换器
时间:2014-03-07 09:57:57       作者:Freescale       来源:中电网
Freescale公司的PF0200是12路可配置的电源管理集成电路(PMIC),提供高度可编程/可配置架构,以及全集成功率器件,具有最小化外接元件.器件具有四个降压转换器,一个升压稳压器,六个线性稳压器,RTC电源以及纽扣电池充电器,并提供应用处理器,存储器,系统外设等完整系统,主要用在平板电脑,IPTV,工业控制,医疗监控,家庭自动化/告警/能量管理.本文介绍了PF0200主要特性, 功能框图, 简化应用框图, 典型应用电路图及其材料清单, 评估板KITPF0200EPEVBE主要特性,建立图,电路图,材料清单和PCB元件布局图.
The PF0200 Power Management Integrated Circuit (PMIC) provides a highly programmable/ configurable architecture, with fully integrated power devices and minimal external components. With up to four buck converters, one boost regulator, six linear regulators, RTC supply, and coin-cell charger, the PF0200 can provide power for a complete system, including applications processors, memory, and system peripherals, in a wide range of applications. With on-chip One Time Programmable (OTP) memory, the PF0200 is available in pre-programmed standard versions, or non-programmed to support custom programming. The PF0200 is especially suited to the i.MX 6SoloLite, i.MX 6Solo and i.MX 6DualLite versions of the i.MX 6 family of devices and is supported by full system level reference designs, and pre-programmed versions of the device. This device is powered by SMARTMOS technology.
PF0200主要特性:
查看全文
