On Semi公司的NCV8876是汽车级起-停非同步升压控制器,能驱动外接N沟MOSFET.器件采用峰值电流模式控制和内部斜率补偿,保护特性包括逐个周期限流,保护和关断.主要用在汽车起动/停止控制.本文介绍了NCV8876主要特性和典型应用电路以及评估板NCV887601主要特性,电路图,材料厂清单和PCB布局图.
The NCV8876 is a Non-Synchronous Boost controller designed to supply a minimum output voltage during Start-Stop vehicle operation battery voltage sags. The controller drives an external N-channel MOSFET. The device uses peak current mode control with internal slope compensation. The IC incorporates an internal regulator that supplies charge to the gate driver.Protection features include, cycle-by-cycle current limiting, protection and thermal shutdown.
Additional features include low quiescent current sleep mode operation. The NCV8876 is enabled when the supply voltage drops below 7.3 V, with boost operation initiated when the supply voltage is below 6.8 V.
NCV8876主要特性:
• Automatic Enable Below 7.3 V (Factory Programmable)
• Boost Mode Operation at 6.8 V
• _2% Output Accuracy Over Temperature Range
• Peak Current Mode Control with Internal Slope Compensation
• Externally Adjustable Frequency Operation..
分享到:
