[原创] InfineonICE5QR0680AG 42W双输出开关电源(SMPS)解决方案
关键词:电源管理 开关电源(SMPS) PWM ICE5QR0680AG
时间:2017-07-28 10:27:22       作者:Infineon       来源:中电网
Infineon公司的ICE5QR0680AG是第五代PWM控制器,集成了高压700 V和800 V超级结MOSFET和内部电流稳压器,具有快速起动性能,主要用在离线开关电源(SMPS),适配器,机顶盒,水/空气净化器和TV主电源,空调,冰箱,服务器,PC电源和音频的辅助电源.本文介绍了ICE5QR0680AG主要特性和优势,60W隔离反激开关电源(SMPS)电路图以及采用ICE5QR0680AG的42W双输出12V和5V SMPS准谐振演示板主要特性和优势,主要指标,电路图,材料清单和PCB设计图.
To achieve fast start-up performance, 5th generation controller utilize the high voltageMOSFET together with an internal current regulator to operate the start-up sequence in a safe and rapid manner, which is commonly known as cascode configuration.
Upsized zero crossing counters for valley detection
With the implementation of 10 zero crossing counters, the ability to detect AC line input level and an intelligent adaptive digital algorithm (patent pending), it enabled the 5th generation controller to minimize the spread of switching frequency under different AC line input conditions. This innovative approach has enabled SMPS designers to designwith higher switching frequency to take advantage of smaller magnetics and lowering ofsystem BOM cost.
Run cooler with CoolMOSTM P7 family
查看全文
