关键词:ARM Cortex®-M4 MCU 马达控制 可穿戴设备 Wi-Fi模块 医疗设备 家庭音频设备
时间:2017-01-17 10:27:49 作者:ST 来源:中电网
ST公司的STM32F413ZH是基于高性能ARM® Cortex®-M4 32位RISC核的MCU,工作频率高达100MHz,提供一个12位ADC,两个12位DAC,低功耗RTC,12个别通用16位计时器,两个通用32位计时器和一个低功耗计时器,多达1.5MB闪存和320KB SRAM,工作电压1.7 V 到 3.6 V,主要用在马达驱动和应用控制,可穿戴设备,Wi-Fi模块,医疗设备,家庭音频设备,手机传感器集线器,工业应用如PLC,逆变器和电路中断器,告警系统,视频连接和HVAC.本文介绍了STM32F413ZH主要特性和框图,以及开发板STM32 Nucleo-144主要特性,硬件框图,正/背面元件布局图,电路图和材料清单.
The STM32F413XG/H devices are based on the high-performance ARM® Cortex®-M4 32-bit RISC core operating at a frequency of up to 100 MHz. Their Cortex®-M4 core features a Floating point unit (FPU) single precision which supports all ARM single-precision data-processing instructions and data types. It also implements a full set of DSP instructions and a memory protection unit (MPU) which enhances application security.
The STM32F413XG/H devices belong to the STM32F4 access product lines (with products combining power efficiency, performance and integration) while adding a new innovative feature called Batch Acquisition Mode (BAM) allowing to save even more power consumption during data batching.
..分享到:
