[原创] ST STGIB15CH60TS-L马达控制电源板参考设计
关键词:工业控制 马达控制 IGBT IPM STGIB15CH60TS-L
时间:2016-04-18 09:11:26       作者:ST       来源:中电网
ST公司的STGIB15CH60TS-L是SLLIMM™ - 2系列低损耗智能电源模块(IPM),提供在低压MCU和主电源马达间直接连接,工作频率高达20kHz,功率范围高达3kW.器件在25°C时额定电流3A-5A,耐压600V,主要用于马达驱动的三相逆变器,以及家用电器如洗衣机,电冰箱,空调和缝纫机等.本文介绍了STGIB15CH60TS-L 主要特性,功能框图和应用框图,以及马达控制电源板STEVAL-IPM15B主要特性,架构图,电路图,材料清单和PCB设计图.
SLLIMM™ - 2nd series IPM, 3-phase inverter, 20 A, 600 V short-circuit rugged IGBTs ST’s SLLIMM™ family of small low-loss intelligent molded modules enhances the efficiency of home appliance motor drives working up to 20 kHz in hard-switching circuitries and of applications with a power range up to 3 kW.
ST’s intelligent power modules (IPMs) provide a direct connection between a low-voltage microcontroller and a mains-powered electric motor. They greatly reduce costs by simplifying design and significantly reducing component count while saving space, improving reliability and lowering EMI. Available in several package options (fully molded and DBC), current ratings and driving options, they feature the best compromise between conduction and switching losses, along with outstanding robustness and EMI behavior.
STGIB15CH60TS-L主要特性:
查看全文
