Power Integrations 2SP0215F2Q0C双路IGBT栅极驱动器解决方案关键词:电源管理 栅极驱动器 Power Integrations2SP0215F2Q0C
时间:2022-6-29 16:43:10 来源:中电网
Power Integrations公司的 2SP0215F2Q0C是用于EconoDUAL 17mm模块驱动高达1200V的IGBT开关的双路栅极驱动器.即插即用栅极驱动器板设计用于需要汽车认证的应用如电动公交车, 电动卡车,纯电动汽车,混合电动汽车,或工作在1000V纯电动汽车电池电压的燃料电池逆变器.栅极驱动器提供汽车有关的保护功能和诊断.电流隔离IGBT模块集成了NTC读出,提供了IGBT模块温度信息.作为即插即用栅极驱动器, 2SP0215F2Q0C特性匹配了特别功率模块的要求.
Power Integrations公司的 2SP0215F2Q0C是用于EconoDUAL 17mm模块驱动高达1200V的IGBT开关的双路栅极驱动器.即插即用栅极驱动器板设计用于需要汽车认证的应用如电动公交车, 电动卡车,纯电动汽车,混合电动汽车,或工作在1000V纯电动汽车电池电压的燃料电池逆变器.栅极驱动器提供汽车有关的保护功能和诊断.电流隔离IGBT模块集成了NTC读出,提供了IGBT模块温度信息.作为即插即用栅极驱动器, 2SP0215F2Q0C特性匹配了特别功率模块的要求.指令信号经由FluxLink隔离技术从初级边(1N1和1N2)转换到次级边.次级边电源提供正栅极电压和在打开过程中驱动功率半导体栅极.峰值输出栅极电流为+20A/-15A,高达20kHz开关频率,在最高环境温度每路栅极功率为1.5W,数字通信接口,工作温度-40 °C到+85 °C,可工作在高达5500米高度,5V输入逻辑.主要用在电动公交车, 电动卡车,纯电动汽车,混合电动汽车,柴油发动机逆变器, 燃料电池逆变器,农用和建筑汽车和设备,其它汽车和工业应用以及通用驱动器.本文介绍了2SP0215F2Q0C 产品亮点, 功能框图以及RDHP-2250Q适配器板主要特性,电路图,材料清单,PCB设计图和3D提供图.
The 2SP0215F2Q0C is a dual channel gate driver for EconoDUAL 17 mm modules driving IGBT switches. The Plug-and-Play gate driver board is designed for applications requiring automotive qualification like e-BUS, e-Truck, Battery Electrical Vehicles, Hybrid Electrical Vehicles or fuel cell inverters operating up to 1000 V battery voltage.
The gate driver provides automotive related protection functionalities and diagnostics. A galvanic isolated IGBT module integrated NTC read-out provides IGBT module temperature information.
As a plug-and-play gate driver, the 2SP0215F2Q0C characteristics match the requirements of specific power modules. The command signals are transferred from the primary-side (IN1 and IN2) to the secondary-side via the FluxLink isolation technology. Secondary-side supplies provide a positive gate voltage and drives the power semiconductor gate during the turn-on process and while turned on.
Similar, the secondary-side supplies provide a negative gate voltage and discharges the gate during the turn-off proc...
