关键词:无线MCU ZigBee 无线通信 IPv6 6LoWPAN ATmega256RFR2
时间:2014-10-28 10:56:51 来源:中电网
Atmel公司的ATmega256/128/64RFR2是集成了2.4GHz ISM频段收发器的低功耗CMOS RISC架构的8位AVR MCU,16MHz时的吞吐量高达16MIPS.其收发器具有250kbps到2Mkbps的数据速率,帧处理,接收灵敏度-100dBm,发送输出功率高达3.5dBm,主要用于具有ZigBee® / IEEE 802.15.4-2011/2006/2003™功能设备,通用2.4GHz ISM收发器,以及RF4CE, SP100, WirelessHART™, ISM应用和IPv6 / 6LoWPAN互联网.本文介绍了ATmega256/128/64RFR2主要特性和框图, ATmega256RFR2 ZigBit扩展板主要特性,电路图,材料清单和PCB设计图.
The ATmega256/128/64RFR2 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture combined with a high data rate transceiver for the 2.4 GHz ISM band.
By executing powerful instructions in a single clock cycle, the device achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
The radio transceiver provides high data rates from 250 kb/s up to 2 Mb/s, frame handling, outstanding receiver sensitivity and high transmit output power enabling a very robust wireless communication.
ATmega256/128/64RFR2主要特性:
• Network support by hardware assisted Multiple PAN Address Filtering
• Advanced Hardware assisted Reduced Power Consumption..
分享到:
