关键词:电源管理 AC/DC转换器 PWM 开关电源 SMPS
时间:2012-07-19 09:47:20 作者:vFairchild 来源:FSL206MR
Fairchild 公司的FSL206MR集成了PWM和SenseFET,特别适用外接元件最少的高性能离线开关电源(SMPS).内部的SenseFET耐压650V,固定工作频率67kHz,265VAC无偏压绕组的无负载功耗小于150mW,具有多种保护,主要用在STB,DVD和DVCD播放器的开关电源,辅助电源.本文介绍了FSL206MR主要特性,方框图,典型应用电路图以及FSL206MR 5W评估板主要指标,电路图,材料清单和PCB布局图.
The FSL206MR integrated Pulse-Width Modulator (PWM) and SenseFET is specifically designed for high performance offline Switched-Mode Power Supplies (SMPS) with minimal external components. This device integrates high-voltage power regulators that combine an avalanche-rugged SenseFET with a Current-Mode PWM control block.
The integrated PWM controller includes: 7.8V regulator for no bias winding, Under-Voltage Lockout (UVLO) protection, Leading-Edge Blanking (LEB), an optimized gate turn-on/turn-off driver, EMI attenuator, Thermal Shutdown (TSD) protection, temperature-compensated precision current sources for loop compensation, and fault-protection circuitry such as; Overload Protection (OLP), Over-Voltage Protection (OVP), Abnormal Over-Current Protection (AOCP), and Line Under-Voltage Protection (LUVP). During startup, the FSL206MR offers good soft-start performance.
分享到:
