ST STEVAL-IFN004V1 BLDC步进马达驱动方案
关键词:工业控制 马达驱动 BLDC
时间:2011-12-27 16:04:13       作者:ST       来源:STEVAL-IFN004V1
ST公司的STM8S105xx是8位MCU,提供16-32KB闪存程序存储器和数据EEPROM,读/写次数高达300k,具有降低系统成本的优势,CPU工作频率16MHz,工作电压2.95V-5.5V. ST公司的STEVAL-IFN004V1评估板是采用L6230和STM8的六步进马达驱动器,DC电压从8V到48V,没个输出最大负载电流1.4 Ar.m.s(峰值2.8A),集成了5V DC/DC稳压器,适用于冷却风扇和泵.本文介绍了STM8S105xx主要优势和特性,方框图, STEVAL-IFN004V1评估板主要特性,电路图和材料清单与PCB布局图.
The STM8S105xx access line 8-bit microcontrollers offer from 16 to 32 Kbytes Flash program memory, plus integrated true data EEPROM. They are referred to as medium-density devices in the STM8S microcontroller family reference manual (RM0016).
STM8S105xx主要优势:
All devices of the STM8S105xx access line provide the following benefits:
• Reduced system cost
- Integrated true data EEPROM for up to 300 k write/erase cycles
- High system integration level with internal clock oscillators, watchdog and brown-out reset.
• Performance and robustness
- 16 MHz CPU clock frequency
- Robust I/O, independent watchdogs with separate clock source
- Clock security system
• Short development cycles
查看全文
