TI DRV8833马达驱动解决方案
关键词:工业控制 马达驱动 机器人
时间:2011-12-20 11:44:42       作者:TI       来源:DRV8833
TI公司的DRV8833是双桥马达驱动器解决方案,包括有两个H桥驱动器,可驱动两个DC电刷马达,或一个步进马达, 螺线管和其它电感负载. DRV8833具有PWM绕组电流调整/限制,H桥的输出电流1.5A RMS,2A峰值,工作电压2.7V-10.8V,主要用在电池玩具,视频照相鸡,办公室自动设备,游戏机和机器人.本文介绍了DRV8833主要特性,方框图,应用电路以及DRV8833评估模块电路图.
The DRV8833 provides a dual bridge motor driver solution for toys, printers, and other mechatronic applications.
The device has two H-bridge drivers, and can drive two DC brush motors, a bipolar stepper motor, solenoids, or other inductive loads.
The output driver block of each H-bridge consists of N-channel power MOSFET’s configured as an H-bridge to drive the motor windings. Each H-bridge includes circuitry to regulate or limit the winding current.
With proper PCB design, each H-bridge of the DRV8833 is capable of driving up to 1.5-A RMS (or DC) continuously, at 25°C with a VM supply of 5 V. It can support peak currents of up to 2 A per bridge. Current capability is reduced slightly at lower VM voltages.
Internal shutdown functions with a fault output pin are provided for over current protection, short circuit protection, under voltage lockout and overtemperature. A low-power sleep mode is also provided.
查看全文
