Holtek HT7A4016非隔离式DC电源解决方案
关键词:电源管理 DC/DC转换器
时间:2011-12-20 11:45:58       作者:Holtek       来源:HT7A4016
Holtek公司的HT7A4016是低功耗宽温度范围的通用电流模式PWM控制器,满足能量之星2.0规范,起动电流低于20uA和很低工作电流,ESD保护大于3kV,调整振荡器精度±5%,内部具有斜率补偿,主要用在开关电源AC/DC适配器,DC/DC降压/升压转换器,LCD/LED TV的LED背光照明.本文介绍了HT7A4016主要特性,方框图以及针对各种不同应用电路的参考设计电路.
The HT7A4016 is a controller IC that includes the necessary features to implement off-line or DC-DC current mode control schemes with a minimal external parts count. Internal circuits include a specially designed Mixed-Mode/Analog Interface for multi-function and multi-topology control schemes (DC-DC Buck/Boost, Off-line AC-DC), a trimmed oscillator for precise duty-cycle control under voltage lockout with a start-up current of less than 0.5mA, a wide temperature range, precise voltage reference, internal Slope Compensation and Leading-Edge Blanking. The HT7A4016 features basic system protection functions such as Cycle-by-Cycle Current Limiting and Under Voltage Lock-Out (UVLO). A Multi-Function Pin can be used as a dimming function for LED driving, and as a primary feedback control f o r Primary - Side Feed back AC - DC applications.
HT7A4016主要特性:
• High Performance, Low Cost Current Mode PWM Controller especially designed for Energy Star 2.0
查看全文
