TI 公司的CC1120是 全集成的868/915MHz单片无线电收发器。器件集成了所有的滤波器,因此不需要外接SAW和IF滤波器,支持包处理,数据缓冲,突发传输,空闲信道评估,链接指示和无线电微弱信号。工作参数可通过SPI接口控制,工作电压2V-3.6V,符合欧洲的ETSI EN 300 220与ETSI EN 54-25 ,美国的FCC CRF47 Part 15, FCC CFR47 Part 90, 24与101以及日本的ARIB RCR STD-T30, ARIB STD-T67, ARIB STD-T96规范,主要用在窄带超低功耗无线系统,无线计量和无线智能电网(AMR和AMI),IEEE 802.15.4g系统,家庭和建筑物自动化,工业控制,无线保健,无线传感器网络和有源RFID,私人移动无线电等。本文介绍了CC1120主要特性,系统框图,典型应用电路图以及868/915MHz EM参考设计电路图,材料清单和元件布局图。
The CC1120 is a fully integrated single-chip radio transceiver designed for high performance at low power and low voltage operation in cost effective wireless systems. All filters are integrated, removing the need for costly external SAW and IF filters. The device is mainly intended for the ISM (Industrial, Scientific and Medical) and SRD (Short Range Device) frequency bands at 164-192 MHz, 410-480 MHz and 820-960 MHz.
分享到:
