Atmel ATA6663低成本LIN应用开发方案
关键词:汽车电子 LIN收发器 LIN总线
时间:2011-09-16 10:59:19       作者:Atmel       来源:ATA6663
Atmel公司的ATA6663是低成本LIN总线收发器,和LIN指标2.0, 2.1与SAEJ2602-2
兼容,工作电压5V-27V,波特率高达20K波特,完全和3.3V与5V器件兼容,具有正常和睡眠模式,睡眠模式的功耗低于10μA,主要用在LIN总线网络如汽车车体电子系统,包括门模块,座位控制,智能传感器和动力总成应用.本文介绍了ATA6663/ATA6664主要特性,方框图, 应用框图以及在汽车网络中应用框图和ATA6663/ATA6664开发板主要特性,电路图和PCBV元件布局图.
The Atmel ATA6663 is a fully integrated LIN transceiver complying with the LIN specification 2.0, 2.1 and SAEJ2602-2. The Atmel ATA6664 is an identical version,the only difference is that the TXD-dominant Time-out function is disabled so the device is able to send a static low signal to the LIN bus. It interfaces the LIN protocol handler and the physical layer. The device is designed to handle the low-speed data communication in vehicles, for example, in convenience electronics. Improved slope control at the LIN bus ensures secure data communication at up to 20Kbaud with an RC oscillator for protocol handling. Sleep Mode guarantees minimal current consumption even in the case of a floating bus line or a short circuit on the LIN bus to GND.The ATA6663/ATA6664 feature advanced EMI and ESD performance.
ATA6663/ATA6664主要特性:
• Operating Range from 5V to 27V
• Baud Rate up to 20Kbaud
查看全文
