时间:2011-01-19 13:03:28 作者:Linear 来源:LTC2379
Linear 公司的LTC2379-18是低功耗高速18位SAR模数转换器(ADC),单电源2.5V工作,± VREF全差分输入从2.5V 到5.1V,功耗仅为18mW,INL为±2LSB,18位精度时不丢失码,而SNR达到101dB,高速SPI接口支持1.8V, 2.5V, 3.3V 和 5V逻辑电平,吞吐量达1.6Msps,数字增益压缩(DGC),主要用在医疗图像,高速数据采集,手提仪表,工业过程控制和低功耗ATE等。本文介绍了LTC2379-18主要特性,方框图,典型应用电路图,输入信号链以及演示板部分电路图和LT6530与LTC2379-18连接配置图。
The LTC2379-18 is a low noise, low power, high speed 18-bit successive approximation register (SAR) ADC. Operating from a 2.5V supply, the LTC2379-18 has a ± VREF fully differential input range with VREF ranging from 2.5V to 5.1V. The LTC2379-18 consumes only 18mW and achieves ±2LSB INL maximum, no missing codes at 18-bits with 101dB SNR.
The LTC2379-18 has a high speed SPI-compatible serial interface that supports 1.8V, 2.5V, 3.3V and 5V logic while also featuring a daisychain mode. The fast 1.6Msps throughput with no cycle latency makes the LTC2379-18 ideally suited for a wide variety of high speed applications.
An internal oscillator sets the conversion time, easing external timing considerations. The LTC2379-18 automatically powers down between conversions, leading to reduced power dissipation that scales with the sampling rate.
分享到:
