ADI AD4030-24 24位2MSPS取样SAR ADC解决方案关键词:SAR ADC自动测试设备(ATE)工业控制医疗仪器 ADI AD4030-24
时间:2022-7-18 14:52:15 来源:中电网
ADI公司的AD4030-24是 24位取样频率2MSPS的具有Easy Drive™的逐次求近寄存器(SAR)的模数转换器(ADC).器件具有保证最大±0.9 ppm积分非线性(INL)和不丢失码24位,在−40°C 到 +125°C温度范围内获得无与伦比的精度.低漂移内部精密基准缓冲器不需要和其它系统电路共享基准电压,采用5V基准电压时提供动态范围为109dB. 低噪声基准使得信号链需要较低的增益和更低的功耗,具有可编信号抽取比率的阻塞平均滤波器能增加动态范围
ADI公司的AD4030-24是 24位取样频率2MSPS的具有Easy Drive™的逐次求近寄存器(SAR)的模数转换器(ADC).器件具有保证最大±0.9 ppm积分非线性(INL)和不丢失码24位,在−40°C 到 +125°C温度范围内获得无与伦比的精度.低漂移内部精密基准缓冲器不需要和其它系统电路共享基准电压,采用5V基准电压时提供动态范围为109dB. 低噪声基准使得信号链需要较低的增益和更低的功耗,具有可编信号抽取比率的阻塞平均滤波器能增加动态范围高达155.5dB.宽差分输入和共模范围允许输入采用满±VREF范围而不会出现饱和,简化了信号调和的要求和系统校准.容易驱车模拟输入改善了设定加宽了和AD4030-24兼容的模拟前端元件的选择.器件支持单端和差分两种信号.器件的SNR为108.4dB,THD为-127dB,而NSD为 −169 dBFS/Hz.回声时钟模式简化了数字隔离器的使用,和1.2V到1.8V逻辑电平兼容,采用7 mm × 7 mm 64球CSP_BGA封装.主要用在自动测试设备(ATE),数字控制回路,医疗设备,地震学,半导体制造和科学仪器.本文介绍了AD4030-24主要特性,功能框图, 差分驱动器模拟前端和增益双缓冲器配置图以及评估板(ZedBoard )EVAL-AD4630-24FMCZ/EVAL-AD4030-24FMCZ主要特性,电路图,材料清单和PCB设计图.
The AD4030-24 is a 2 MSPS successive approximation register (SAR) analog-to-digital converter (ADC) with Easy Drive™. With a guaranteed maximum ±0.9 ppm integral nonlinearity (INL) and no missing codes at 24-bits, the AD4030-24 achieves unparalleled
precision from −40°C to +125°C. Figure 1 shows the functional architecture of the AD4030-24.
A low-drift, internal precision reference buffer eases voltage reference sharing with other system circuitry. The AD4030-24 offers a typical dynamic range of 109 dB when using a 5 V reference.
The low noise floor enables signal chains requiring less gain and lower power. A block averaging filter with programmable decimation ratio can increase dynamic range up to 155.5 dB. The wide differential input and common mode ranges allow inputs to use the full ±VREF range without saturating, simplifying signal conditioning requirements and system calibration. The improved settling of the Easy Drive analog in...
