TI 公司的UCD90124是 12路 PMBus/I2C可寻址的电源监测器,集成了可监测13路电源的电压,电流或温度输入的12位ADC,所有的电源400us取样一次,具有风扇控制和监测以及可闭环监测10个电源。器件内部有温度传感器,以及JTAG和 I2C/SMBus/PMBus接口,主要用在工业和自动测试设备(ATE)。本文介绍UCD90124主要特性,方框图,典型应用电路图以及UCD90120和UCD90124评估模块主要特性,方框图,详细电路和材料清单。
The UCD90124 is a 12-rail PMBus/I2C addressable power-supply sequencer and system-health monitor. The device integrates a 12-bit ADC for monitoring up to 13 power-supply voltage, current, or temperature inputs. Twenty-six GPIO pins can be used for power supply enables, power-on reset signals, external interrupts, cascading, or other system functions. Twelve of these pins offer PWM functionality. Using these pins, the UCD90124 offers support for fan control, margining, and general-purpose PWM functions.
Fan-control signals can be sent using PMBus commands or generated from one of two built-in fan-control algorithms. PWM outputs combined with temperature and fan-speed measurements provide a complete fan-control solution for up to four independent fans.
UCD90124主要特性:
分享到:
