Fairchild FSEZ1317低待机功耗PWM电源方案
关键词:电源管理 AC/DC转换器 PWM
时间:2010-03-03 10:32:00       来源:Fairchild
Fairchild 公司的FSEZ1317是集成功率MOSFET的初级边调整(PSR)的PWM控制器,待机功耗低于30mW,高电压起动,恒压(CV)和恒流(CC)控制而不需要次级反馈电路。FSEZ1317主要用在手机,无绳电话,PDA,数码相机等充电器以及替代线性变压器和RCC SMPS等。本文介绍FSEZ1317主要特性,方框图以及典型典型应用电路图。
FSEZ1317: Primary-Side-Regulation PWM with POWER MOSFET Integrated
This third-generation Primary Side Regulation (PSR) and highly integrated PWM controller provides several features to enhance the performance of low-power flyback converters. The proprietary topology, TRUECURRENT™, of FSEZ1317 enables precise CC regulation and simplified circuit design for batterycharger applications. A low-cost, smaller, and lighter charger results, as compared to a conventional design or a linear transformer.
To minimize standby power consumption, the proprietary green mode provides off-time modulation to linearly decrease PWM frequency under light-load conditions. Green mode assists the power supply in meeting power conservation requirements.
FSEZ1317主要特性:
□ Low Standby Power Under 30mW
□ High-Voltage Startup
□ Fewest External Component Counts
□ Constant-Voltage (CV) and Constant-Current (CC) Control without Secondary-Feedback Circuitry
查看全文
