Allegro 公司的STA6940M是带PWM控制的无刷DC马达驱动器,集成了低功耗CMOS兼容的逻辑(3.5V-5.5V)和大电流高压功率MOSFET输出,输出电流有固定的关断时间和PWM控制,工作电压从10V到40V,正常工作电流4A,最大电流8A.本文介绍了STA6940M主要特性和优势, 功能方框图和典型应用电路以及参考元件数值.
STA6940M: Brushed DC Motor Driver IC With PWM Control
Combining low-power CMOS-compatible logic with highcurrent, high-voltage power MOSFET outputs, the STA6940M provides complete control and drive for brush DC motors. It provides internal fixed off time, pulse-width modulation (PWM) control of the output current, rated for 4 A normal operating level.
The CMOS logic section provides four modes of operation: forward and reverse normal drive rotation, outputs-off free spin (coast), and electronic braking.
The innovative multi-chip internal structure separates the main logic IC (MIC) from the four N-channel power MOSFETs. This results in lower thermal resistance and greater efficiency.
PWM control allows constant-current control of output while reducing heat generation and power losses by providing fixed off-time dual decay modes. The internal charge pump ensures full power availability for switching.
STA6940M主要特性和优势:
分享到:
