Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Infineon 2ED4820-EM 48VÖÇÄܸ߱ßMOSFETÕ¤¼«Çý¶¯Æ÷·½°¸
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí Æû³µµç×Ó Õ¤¼«Çý¶¯Æ÷ DC£¯DCת»»Æ÷ Infineon 2ED4820£­EM
ʱ¼ä£º2022-03-01 15:33:02       À´Ô´£ºÖеçÍø
Infineon¹«Ë¾µÄ2ED4820-EMÊÇÓÃÓÚ48VÆû³µÓ¦ÓõÄÕ¤¼«Çý¶¯Æ÷,¾ßÓй¦ÄÜÇ¿´óµÄÕ¤¼«Êä³ö,ÄÜÇý¶¯²¢ÁªµÄ¶à¸öMOSFET,ÒÔ×î´óÏ޶ȽµµÍµ¼Í¨ËðºÄ.ÓÉÓÚËüµÄÁ½ÖÖÕ¤¼«Êä³ö,ËüÖ§³Ö±³¶Ô±³µÄÅäÖÃ,¹²Ô´ºÍ¹²Â©Á½Öֽṹ.ÔÚ¹²Ô´¼«ÅäÖÃ,Ò»¸öÕ¤¼«Êä³öÄÜÓÃÀ´Ô¤³äµç´óÈÝÐÔ¸ºÔØ. 2ED4820-EM²úÉúÕ¤¼«Êä³öµÄµçÔ´,ËüÊÇ»ùÓÚ¼¯³É¾ßÓÐÍâ½Ó±ÃºÍÏäʽµçÈݵÄÒ»¼¶µçºÉ±Ã.Æ÷¼þ¾ßÓÐSPI½Ó¿Ú,ÓÃÓÚÈÝÒ×ÅäÖÃ,Õï¶ÏºÍ¿ØÖÆ.Æ÷¼þµÄµçÔ´µçѹ´Ó20Vµ½70V,¾ßÓÐÁ½¸ö¶ÀÁ¢µÄ¸ß±ßÕ¤¼«Çý¶¯Æ÷Êä³ö,1AÏÂÀ­ºÍ0.3AÉÏÀ­ÓÃÓÚ¿ìËÙ¿ª¹ØµÄ½Óͨ/¹Ø¶Ï.ÔÚ˯ÃßģʽµÍµçÔ´µçÁ÷BAT_QСÓÚ5 ¦ÌA.Æ÷¼þ¾ßÓÐÒÔϵı£»¤ÌØÐÔ:µçԴǷѹºÍ¹ýѹ¼ì²â²¢¾ßÓпÉÅäÖÃÖØÆ÷¼ÆÊ±Æ÷,µçºÉǷѹ¼ì²â,Õ¤¼«µ½Ô´¼«Ç·Ñ¹¼ì²â,¿ÉÅäÖ鼫µ½Ô´¼«¹ýѹ¼ì²â,¿ÉÅäÖùýÁ÷¼ì²âÒÔ¼°ÄÚ²¿³¬Î¸澯ºÍ±£»¤.Ö÷ÒªÓÃÔÚ48Vµç³Ø±£»¤¿ª¹Ø,ÓÃÓÚDC/DCת»»Æ÷,Âí´ï¿ØÖƵ¥ÔªµÈµÄ48VÊäÈë±£»¤,48VÆû³µ¼ÌµçÆ÷ºÍ±£ÏÕË¿Ìæ´úÆ·.±¾ÎĽéÉÜÁË2ED4820-EMÖ÷ÒªÌØÐÔ,¿òͼ, 48Vµç³ØÖ÷¿ª¹ØÓ¦ÓÿòͼºÍ¾Õ»¨Á´Á¬½Óͼ,ÒÔ¼°ÆÀ¹À°å2ED4820-EM EB2 2HSV48Ö÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
2ED4820-EM is a gate driver designed for high current 48 V automotive applications, with powerful gate outputs to drive many MOSFETs in parallel in order to minimize the conduction losses. It supports the back-to-back configuration, both common source and common drain structures, thanks to its two gate outputs.
In common source configuration, one gate output can be used to pre-charge highly capacitive loads.
2ED4820-EM generates the supply for the gate outputs based on an integrated one-stage charge pump with external pump and tank capacitors.2ED4820-EM comes with an SPI interface, for easy configuration, diagnosis and control.
Seve..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
