[原创]On Semi NFAM5065L4B全集成650V50A逆变器功率模块解决方案
关键词:工业自动化 马达驱动 IPM BLDC PMSM On Semi NFAM5065L4B
时间:2021-10-11 16:41:11       来源:中电网
On Semi公司的NFAM5065L4B是全集成逆变器功率模块,包括了单独的高边栅极驱动器,LVIC,六个IGBT和一个温度传感器(TVS),适用脑于驱动永磁同步(PMSM)马达,无刷DC(BLDC)马达和交流异步马达.IGBT可配置成三相桥式,具有单独发射极连接以用于选择控制算法的有最大灵活性的低位腿.功率级具有欠压锁住保护(UVP),而所提供的内部的升压二极管用于高边栅极升压驱动.器件具有三相650V 50A IGBT模块和单独的驱动器.器件具有UL1557 认证(文件No.339285).器件是无铅和RoHS兼容的.主要用在工业驱动,工业泵,工业风扇和工业自动化.本文介绍了NFAM5065L4B主要特性,等效框图和应用电路图,以及开发板SECO-MDK-4KW-65SPM31-GEVB主要特性,主要指标,框图和电路图,材料清单和PCB设计图.
The NFAM5065L4B is a fully-integrated inverter power moduleconsisting of an independent High side gate driver, LVIC, six IGBTsand a temperature sensor (VTS), suitable for driving permanentmagnet synchronous (PMSM) motors, brushless DC (BLDC) motorsand AC asynchronous motors. The IGBTs are configured ina three-phase bridge with separate emitter connections for the lowerlegs for maximum flexibility in the choice of control algorithm.
The power stage has under voltage lockout protection (UVP).
Internal boost diodes are provided for high side gate boost drive.
NFAM5065L4B主要特性:
• Three-phase 650 V, 50 A IGBT Module with Independent Drivers
• Active Logic Interface
• Built-in Undervoltage Protection (UVP)
查看全文
