[原创]ADI ADPA110745.0 dBm (35 W) 4.8 -6.0 GHz GaN功率放大方案
关键词:GaN功率放大器 微波通信 雷达 ADI ADPA110745
时间:2021-08-03 13:29:10       来源:中电网
ADI公司的ADPA1107是在4.8 -6.0 GHz频段提供45.0 dBm功率(35 W)的宽带氮化镓(GaN)功率放大器,典型的附加功率效率(PAE)为56.5%(PIN=27.0dBm).5.4 GHz到6.0 GHz的增益平坦度为±0.5 dB.4.8 GHz到 5.4 GHz的小信号增益典型为30.5dB,频率范围为4.8 GHz到 5.4 GHz.VDD为28V(IDQ = 350 mA,10%占空比).输入回波损耗为16.0dB,输出回波损耗为13.5dB.40引脚6 mm × 6 mm LFCSP封装.主要用在气象雷达,军用雷达和船用雷达.本文介绍了ADPA1107主要特性,功能框图和电指标, 基本连接图以及评估板ADPA1107-EVALZ主要特性,电路图,建立框图,材料清单和PCB设计图.
The ADPA1107 is a gallium nitride (GaN), broadband power amplifier, delivering 45.0 dBm (35 W) with 56.5% typical power added efficiency (PAE) across a bandwidth of 4.8 GHz to 6.0 GHz. The ADPA1107 provides ±0.5 dB gain flatness from 5.4 GHz to 6.0 GHz.
The ADPA1107 is ideal for pulsed applications such as radar, public mobile radio, and general-purpose amplification.
The ADPA1107 is housed in a 40-lead, 6 mm × 6 mm, lead frame chip scale package (LFCSP).
ADPA1107主要特性:
POUT with PIN = 27.0 dBm: 45.0 dBm typical at 5.4 GHz to 6.0 GHz
Small signal gain: 30.5 dB typical at 4.8 GHz to 5.4 GHz
Frequency range: 4.8 GHz to 6.0 GHz
PAE with PIN = 27.0 dBm: 56.5% typical at 5.4 GHz to 6.0 GHz
VDD: 28 V at IDQ = 350 mA with a 10% duty cycle ..
查看全文
