关键词:汽车电子 栅极驱动器 消费类电子 TI UCC23313-Q1
时间:2020-11-27 12:37:33 来源:中电网
TI公司的UCC23313-Q1是用于IGBT,MOSFET和SiC MOSFET的光兼容单路隔离栅极驱动器,具有4.5A源和5.3A沉峰值输出电流和3.75-kVRMS基本隔离指标.UCC23313-Q1电源电压高达33V,能有效地驱动IGBT和SiC功率FET,并能驱动高边和低边功率FET.满足汽车应用的AEC-Q100规范,引脚对引脚地兼容光隔离栅极驱动器,12-V VCC UVLO,轨到轨输出,传输时延最大为105ns,产品间时延匹配最大为25ns,脉宽失真最大为35ns,共模瞬态免疫(CMTI)大于150-kV/μs,隔离层寿命大于50年,工作结温TJ为 –40C 到+150C,符合的安全标准(计划)有6000-VPK 基本隔离per DIN V VDEV0884-11: 2017-01,3.75-kVRMS隔离1秒per UL 1577和CQC 证书per GB4943.1-2011.主要用在电动汽车(EV)的牵引逆变器,车载充电器和DC充电站,HVAC,加热器,工业马达驱动.本文介绍了UCC23313-Q1主要特性,功能框图,驱动IGBT应用电路和多种配置电路,评估模块UCC23513EVM-014主要特性,电路图,材料清单和PCB设计图.
The UCC23313-Q1 is an Opto-compatible, singlechannel,isolated gate driver for IGBTs, MOSFETs andSiC MOSFETs, with 4.5-A source and 5.3-A sink peakoutput current and 3.75-kVRMS basic isolation rating.
The high supply voltage range of 33 V allows the useof bipolar supplies to effectively drive IGBTs and SiCpower FETs. UCC23313-Q1 can drive both low sideand high side power FETs. Key features andcharacteristics bring significant performance andreliability upgrades over standard opto-coupler basedgate drivers while maintaining pin-to-pin compatibilityin both schematic and layout design. Performancehighlights include high common..
分享到:
