[原创] TI SAE J1772兼容电动汽车充电器参考设计TIDA-010071
关键词:汽车电子 电动汽车 汽车充电器 AC/DC转换器 充电桩
时间:2019-10-25 11:10:29       来源:中电网
TI公司的TIDA-010071是SAE J1772兼容的电动汽车服务管理设备(EVSE)参考设计,用于Level 1和Level 2级EV充电器.电动汽车服务管理设备(EVSE)从电网给电动汽车(EV)提供安全的电源.EVSE控制系统包括辅助电源,离板的AC/DC大功率电源(仅在DC充电站),能量计量单元,AC和DC剩余电流探测器,隔离监视器单元,带驱动的继电器和接触器,单线双向通信,服务和用户接口.该参考设计具有超低待机隔离的AC/DC辅助电源,紧接转换器和线性稳压器,基于比较器的控制导向接口,以满足SAE J1772标准,以及一个有效继电器和接触器驱动, 以及继电器和接触器上的隔离线电压检测.主要用于AC充电(桩)站和DC充电(桩)站.本文介绍了参考设计TIDA-010071主要特性,AC Level 1和Level 2系统配置图和设计系统主要指标,框图,电路图,材料清单和PCB设计图.
SAE J1772-compliant electric vehicle service equipment reference design for level 1 and 2 EV charger Electric vehicle service equipment (EVSE) facilitatespower delivery to electric vehicles safely from the grid.An EVSE control system consists of an auxiliary powerstage, an off-board AC/DC high power stage (only inDC charging stations), energy metering unit, AC andDC residual current detector, an isolation monitor unit,relays and contactors with drive, two-waycommunication over single wire, and service and userinterfaces. This reference design highlights an ultralowstandby isolated AC/DC auxiliary power stagefollowed by converters and linear regulators, acomparator-based control pilot interface to meet theSAE J1772 standard, an efficient relay and contactordrive, and isolated l..
查看全文
