[原创] Infineon TLE984x系列ARM MCU汽车马达控制方案
关键词:ARM Cortex M0 MCU 汽车电子 马达控制 TLE984x
时间:2017-08-24 11:09:30       作者:Infineon       来源:中电网
Infineon公司的TLE9842-2QX是TLE984x系列中一员,集成了32位ARM® Cortex® M0 MCU核,继电器驱动器,高边开关,LIN收发器和能工作在汽车电池的电源系统.时钟高达40MHz,具有单周期的乘法器,集成了40KB闪存,4KB EEPROM,768B 100次可编存储器(100TP),2KB RAM以及引导ROM,工作电压3.0 V到 28 V,工作温度-40℃ 到150℃,主要用在汽车窗提升,汽车天窗,雨刷,泵马达控制,风扇马达控制等.本文介绍了TLE9842-2QX主要特性,功能框图,简化应用框图及所用外接元件表以及TLE984x系列评估板主要特性,框图,电路图,材料清单和PCB设计图.
TLE9842-2QX is a part of the TLE984x product family. The TLE984x product family integrates an ARM® Cortex® M0 microcontroller core along with relay drivers, high side switches, LIN transceiver and a power supply system that enables the device to operate at the vehicle battery level. The TLE984x family offers scalability in terms of Flash memory sizes ranging from 36kB to 64kB with pin-compatible devices.
The TLE984x family was specifically designed to fit to a wide range of LIN-slave applications where a small package form factor and a minimum number of external components are essential. The TLE984x product family is offered in a leadless VQFN-48 package to save board space.
TLE9842-2QX主要特性:
• 32-bit ARM Cortex-M0 Core
– up to 40 MHz clock frequency
– one clock per machine cycle architecture..
查看全文
