Infineon IPP60R040C7600 W LLC转换器解决方案
关键词:MOSFET CoolMOS C7 电源管理 AC/DC转换器
时间:2015-06-23 13:02:40       作者:Infineon       来源:中电网
Infineon公司的CoolMOS™ C7是依据超级结(SJ)原理设计的高压功率MOSFET,它的导通电阻(RDS(on)低于1Ohm*mm²(40毫欧姆),VDS大于650V,MOSFET dv/dt可达到120V/ns,非常适合用于硬和软开关(PFC和高性能LLC),如大功率高性能开关电源如计算机,服务器,通信设备,UPS和太阳能电源的PFC级和PWM级.本文介绍了IPP60R040C7主要特性,性能参数,以及600W半桥LLC评估板主要特性,电路图,主要元件分布图和PCB设计图.
CoolMOS™ C7 is a revolutionary technology for high voltage powerMOSFETs, designed according to the superjunction (SJ) principle andpioneered by Infineon Technologies.
600V CoolMOS™ C7 series combines the experience of the leading SJMOSFET supplier with high class innovation.
The 600V C7 is the first technology ever with RDS(on)*A below 1Ohm*mm².
IPP60R040C7主要特性:
• Suitable for hard and soft switching (PFC and high performance LLC)
• Increased MOSFET dv/dt ruggedness to 120V/ns
• Increased efficiency due to best in class FOM RDS(on)*Eoss and RDS(on)*Qg
• Best in class RDS(on) /package
• Qualified for industrial grade applications according to JEDEC (J-STD20and JESD22)
IPP60R040C7优势:
• Increased economies of scale by use in PFC and PWM topologies in theapplication..
查看全文
