[原创] Fairchild FNA41560三相马达驱动解决方案
关键词:IGBT 马达驱动 逆变器 BLDC PMSM 家用电器 FNA41560
时间:2014-09-26 10:59:26       作者:Fairchild       来源:中电网
Fairchild公司的FNA41560/FNA41560B2是Motion SPM® 45模块,内置了600V/15A三相IGBT以优化栅极驱动和最小化EMI和损耗,具有多种保护如欠压锁住,过流关断,热监视和故障报告.器件满足要UL标准No. E209204 (UL1557),开关频率5kHz,主要用在家用电器和工业控制的马达驱动.本文介绍了FNA41560/FNA41560B2主要特性,框图, 典型应用电路以及FEBSPM3SPM45_M01MTCA Motion SPM3/45H评估板主要特性,电路图,材料清单和PCB元件布局图与PCB走线图.
FNA41560/FNA41560B2 is a Motion SPM® 45 module providing a fully-featured, high performance inverter output stage for AC Induction, BLDC, and PMSM motors.
These modules integrate optimized gate drive of the built-in IGBTs to minimize EMI and losses, while also providing multiple on-module protection features including under-voltage lockouts, over-current shutdown, thermal monitoring, and fault reporting. The built-in, highspeed HVIC requires only a single supply voltage and translates the incoming logic-level gate inputs to the high-voltage, high-current drive signals required to properly drive the module’s robust short-circuit-rated IGBTs.
Separate negative IGBT terminals are available for each phase to support the widest variety of control algorithms.
FNA41560/FNA41560B2主要特性:
• UL Certified No. E209204 (UL1557)..
查看全文
