Fairchild FL7701智能LED灯驱动解决方案
关键词:电源管理 AC/DC转换器 LED驱动器 开关电源
时间:2012-07-17 10:23:00       作者:Fairchild       来源:FL7701
Fairchild公司的FL7701是带PFC功能的智能LED灯驱动器,内置了高压自偏置电路,输入电压范围80VAC ~ 308VAC,带自动重起模式的AOCP功能,内置超温保护功能,主要用于装饰LED灯和低功率LED灯.本文介绍了FL7701主要特性,方框图,典型和高压应用电路以及带和不带电解电容的应用电路,2.4W LED镇流器电路图,材料清单和PCB布局图.
The FL7701 LED lamp driver is a simple IC with PFC function. The special “adopted digital” technique of the IC can automatically detect input voltage condition and send an internal reference signal for achieving high power factor. When AC input is applied to the IC, PFC function is automatically enabled. Otherwise, when DC input is applied to the IC, PFC function is automatically disabled. The FL7701 does not need a bulk capacitor(electrolytic capacitor) for supply rail stability, which can significantly affect to LED lamp system.
FL7701主要特性:
 Digitally Implemented Active PFC Function (No Additional Circuit Necessary for High PF)
 Built-in HV Supplying Circuit: Self Biasing
 Application Input Range :80VAC ~ 308VAC
 AOCP Function with Auto-Restart Mode
 Built-in Over-Temperature Protection Function
 Cycle-by-Cycle Current Limit
 Current-Sense Pin Open Protection
查看全文
