NXP公司的TEA1721FT是小型低成本开关电源(SMPS)控制器,直接从通用火线电压整流输入,适用于5W以下的应用.器件集成了高压(700V)功率开关,无负载功耗小于30mW,具有过压保护(OVP),欠压锁住(UVLO),超温保护(OTP),主要用于5W手机电池充电器,TV和台式PC的待机电源,白色家电电源.本文介绍了TEA1721主要特性和优势,方框图,5 W GreenChip演示板特性,电路图,材料清单和PCB布局图.
The TEA1721 is a small and low cost module Switched Mode Power Supply (SMPS) controller IC for low power applications (up to 5 W) and operates directly from the rectified universal mains input. The device includes a high voltage power switch (700 V) and has been optimized for flyback converter topologies to provide high-efficiency over the entire load range with ultra-low power consumption in the no-load condition. It provides a circuit for start-up directly from the rectified mains voltage without any external bleeder circuits.
The converter operates as a regulated voltage source from no-load up to the maximum output current and operates as current source that delivers the maximum current over a broad output voltage range. Using the TEA1721, a low power converter can be built at minimum cost and with the minimum number of external components.
分享到:
