Microchip PIC32MX 32位MCU多媒体扩展板解决方案
关键词:通信技术 以太网 USB CAN
时间:2012-06-12 09:44:07       作者:Microchip        来源:PIC32MX
Microchip公司的多媒体扩展板(MEB)采用PIC32系列32位MCU,为PIC32入门板用户,dsPIC33E或PIC24E USB入门板用户提供了灵活解决方案,以开发更高级用户接口.MEB集成了3.2 Color TFT触摸屏QVGA显示器,FCC认证WiFi模块,24位立体声音频代码,三轴加速度计,操纵杆和MicroSD存储器卡插槽,简便和DM320001, DM320003-2, DM320004, DM330012 以及DM240012入门板连接,可用于图像/用户接口,以太网/USB/CAN连接,多任务嵌入式控制以及高性能音频.本文介绍了PIC32MX主要特性,方框图,多媒体扩展板(MEB)主要特性,方框图,电路图,材料清单和PCB元件布局图.
PIC32MX1XX/2XX:32-bit Microcontrollers (up to 128 KB Flash and 32 KB SRAM) with Audio and Graphics Interfaces, USB, and Advanced Analog
Microchip’s 32-bit portfolio with the MIPS® M4K® offers high performance microcontrollers, and all the tools needed to develop your embedded project. With free software, low cost development tools, and pin/peripheral compatibility from 16-bit product lines, PIC32 MCUs shorten time to market and allow your designs to grow. PIC32 gives your application the processing power, memory and peripherals your design needs!
PIC32MX主要特性:
Operating Conditions
• 2.3V to 3.6V, -40ºC to +105ºC, DC to 40 MHz
Core: 40 MHz MIPS32® M4K®
• MIPS16e® mode for up to 40% smaller code size
• 1.56 DMIPS/MHz (Dhrystone 2.1) performance
查看全文
