Maxim DS1878高频光收发参考设计HFRD-49.1
关键词:通信技术 有线通信 光通信 光收发
时间:2011-01-26 09:44:29       作者:Maxim       来源:DS1878
Maxim 公司的DS1878是集成数字LDD接口的SFP+控制器,可以控制和监视SFF, SFP和SFP+ 模块所有的功能,包括所有的SFF-8472功能,支持基于VCSEL, DFB和EML的解决方案。工作电压为+2.85V 到+5.5V,主要用在SFF, SFP和SFP+收发器模块。本文介绍了DS1878主要特性,方框图,高频光收发参考设计HFRD-49.1主要特性,参考设计HFRD-49.1和HFRD-30.1主PCB方框图,参考设计HFRD-49.1电路图和材料清单。
DS1878:SFP+ Controller with Digital LDD Interface
The DS1878 controls and monitors all functions for SFF, SFP, and SFP+ modules including all SFF-8472 functionality.
The combination of the DS1878 with Maxim laser driver/limiting amplifier solutions supports VCSEL, DFB, and EML-based solutions. The device provides APC loop, modulation current control, and eye safety functionality. It continuously monitors for high output current, high bias current, and low and high transmit power to ensure that laser shutdown for eye safety requirements are met without adding external components.
Six ADC channels monitor VCC, temperature, and four external monitor inputs (MON1–MON4) that can be used to meet all monitoring requirements.
查看全文
