Avago AFCT-701SDDZ 10GBE以太网光收发方案
关键词:通信技术 光通信 10GBE SFP+收发器
时间:2009-11-10 10:40:00       来源:Avago
Avago AFCT-701SDDZ 10GBE/1GBE以太网1310nm SFP+光收发器,功耗为850mW,具有完全数字诊断管理接口,光学接口为IEEE 802.3ae 10GBASE-LR,工作速率1.25GBd,主要用于吉比特以太网.本文介绍AFCT-701SDDZ主要特性,功能方框图以及典型应用配置图.
AFCT-701SDDZ :10Gb/1Gb Ethernet, 1310nm SFP+ Transceiver The Avago AFCT-701SDDZ transceiver is part of a family of SFP+ products. This transceiver utilizes Avago’s 1310nm DFB and PIN Detector technology to provide an IEEE 10Gb Ethernet design compliant with the 10GBASELR standard and allows for the operation at 1.25GBd for Gigabit Ethernet Applications. The AFCT-701SDDZ transceiver has the signal and the chassis SFP grounds tied together to enhance the EMI shielding performance of the module, providing extra margin that is particularly useful in higher density applications. The design is based on the new electrical and mechanical specification enhancements to the well known SFP specifications developed by the SFF Committee. These specifications are referred to as SFP+ to recognize these enhancements to previous SFP specifications used for lower speed products.
Avago Technologies is an active participant in the SFF Committee specification development activities.
AFCT-701SDDZ 主要特性:
查看全文
