Linear LTC3880双输出多相降压电源解决方案
关键词:电源管理 DC/DC转换器
时间:2011-01-27 11:30:40       作者:Linear       来源:LTC3880
Linear公司的LTC3880/LTC3880-1是双输出多相DC/DC同步降压开关电源控制器,集成了基于I2C的PMBus兼容的串行接口,采用恒定频率电流模式架构.VIN输出电压从4.5V到24V,输出电压VOUT从0.5V到5.5V,输出电压对温度的变化为±0.5%.器件集成了15位ADC,主要用在大电流分布电源系统,通信,数据通信和存储器系统以及智能能效的电源系统.本文介绍了LTC3880/LTC3880-1主要特性,方框图, 三相工作负载共享连接图, 电感DCR和电阻电流检测电路图,以及多种应用电路图.
Dual Output PolyPhase Step-Down DC/DC Controller with Digital Power System Management
The LTC3880/LTC3880-1 are dual, PolyPhase DC/DC synchronous step-down switching regulator controllers with an I2C-based PMBus compliant serial interface. The controllers use a constant frequency, current mode architecture.
Switching frequency, output voltage, and device address can be programmed using external configuration resistors.
Additionally, parameters can be set via the digital interface or stored in EEPROM. Voltage, current, internal/external temperature and fault status can be read back through the bus interface.
The LTC3880/LTC3880-1 can be configured for Burst Mode operation, discontinuous (pulse-skipping) mode or continuous inductor current mode. The LTC3880 incorporates a 5V linear regulator while the LTC3880-1 uses an external 5V supply for minimum power loss.
查看全文
