NXP TEA1738FT低成本开关电源控制解决方案
关键词:电源管理 开关电源 SMPS AC/DC转换器
时间:2011-01-12 11:10:09       作者:NXP       来源:TEA1738FT
NXP公司的TEA1738FT是低成本GreenChip开关电源(SMPS)控制器,适用于反激拓扑,工作在峰值电流和频率控制模式,频率抖动器可降低EMI,输入电压12V到30V,起动和重置的电流非常低,只有10uA,正常工作没有负载的电流为0.55mA,典型起动电压13.2V,主要应用在高达75W需要效率和低成本的开关电源.本文介绍了TEA1738FT主要特性和优势, 方框图, 典型配置框图和典型应用电路图.
TEA1738FT: GreenChip SMPS control IC
The TEA1738FT is a low cost Switched Mode Power Supply (SMPS) controller IC intended for flyback topologies. It operates in peak current and frequency control mode. Frequency jitter has been implemented to reduce ElectroMagnetic Interference (EMI). Slope compensation is integrated for Continuous Conduction Mode (CCM) operation. The TEA1738FT IC includes OverPower Protection (OPP). This enables the controller to operate under overpower situations for a limited amount of time.
查看全文
