Powercast 公司的P2110 是915MHz RF Powerharvester能量接收器,能把RF转换成DC,存储在电容器上,并提供能量管理,主要用在那些没有电池微功耗的设备.电压输出高达5.25V,输出电流高达50mA,RF输入功率可低至-11.5dBm,主要用于无电池的无线传感器如工业监视,智能电网,结构安全监视,安全保卫,建筑物自动化,农业和油气田以及低功耗电子设备.本文介绍了P2110主要特性,方框图, 典型应用框图和P2110-EVB评估板主要特性,电路图和元件布局图.
P2110: 915 MHz RF Powerharvester™ Receiver
The Powercast P2110 Powerharvester receiver is an RF energy harvesting device that converts RF to DC. Housed in a compact SMD package, the P2110 receiver provides RF energy harvesting and power management for battery-free, micro-power devices. The P2110 converts RF energy to DC and stores it in a capacitor. When a charge threshold on the capacitor is achieved, the P2110 boosts the voltage to the set output voltage level and enables the voltage output. When the charge on the capacitor declines to the low voltage threshold the voltage output is turned off. A microprocessor can be used to optimize the power usage from the P2110 and obtain other data from the component for improving overall system operation.
P2110主要特性:
High conversion efficiency
Converts low-level RF signals enabling long range applications
Regulated voltage output up to 5.25V
分享到:
