AKM AK4186 4(5)线电阻触摸屏控制方案
关键词:消费类电子 触摸屏 ADC 手机 数码相机 DVC 手提设备
时间:2010-10-19 10:13:43       作者:AKM       来源:AK4186
AKM 公司的AK4186是采用12位SAR ADC的 4线/5线电阻触摸屏控制器,具有自动连续测量和测量数据计算功能以及连续读出功能,I2C串行接口,取样速率22.2kHz,工作电压1.6V-3.6V,1.8V的功耗为60uA,并具有自动关机功能。主要用在手机,数码相机,DVC和智能手机以及其它手提设备。本文介绍了AK4186主要特性,方框图,4线和5线典型连接框图,触摸屏输入电路以及AKD4186-A评估板电路图。
The AK4186 is a 4-wire/ 5-wire resistive touch screen controller that incorporates 12bit SAR A/D converter. The AK4186 can detect the pressed screen location with two A/D conversions and it can also measure touch pressure. The AK4186 has both an automatic continuous measurement and a measurement data calculation function. The functions that normally require external processing, such as calculating the average screen input value, are processed by the AK4186. In addition, a new sequential mode achieves short coordinate measurement time while greatly reducing the microprocessor overhead. The AK4186 operates off of supply voltage down to 1.6V in order to connect a low voltage microprocessor. The AK4186 is the best fit for cellular phone, DSC, DVC, smart phone and other portable devices.
AK4186主要特性:
4-wire or 5-wire Touch Screen Interface
I2C Serial Interface
12bit SAR A/D Converter with S/H circuit
Sampling Rate: 22.2kHz
查看全文
