AKM AK5373带USB 2.0接口立体声模数转换解决方案
关键词:消费类电子 ADC MP3 PMP 手机
时间:2010-09-21 10:25:23       作者:AKM       来源:AK5373
AKM 公司的AK5373是带USB 2.0接口的立体声模数转换器(ADC),包括有USB串行接口引擎,USB收发器,音频处理区块,端点以及24位立体声音频ADC。集成的PLL可使用多种取样频率,并集成了麦克风放大器和可编程增益放大器。工作电压3.0V-3.6V。本文介绍了AK5373主要特性,方框图,内部ADC流模式,外部音频处理模式以及系统连接框图,AKD5373-A评估板方框图和电路图与元件布局图。
The AK5373 is a stereo A/D converter with a USB 2.0 interface. The device includes an integrated USB serial interface engine, a USB transceiver, an audio class processing block, endpoints, and a 24-bit stereo audio ADC. An integrated PLL enables the use of multiple sampling frequencies. A microphone amplifier and an integrated programmable gain amplifier are available for processing low-level signals from an analog microphone element. An external EEP-ROM is used to store the descriptor information.
The AK5373 is housed in a 48-pin package. It is a low power device, operating from +3.3V, and consuming just 100mW in active mode and less than 100μA in suspend mode.
AK5373主要特性:
USB 2.0 compliant (full speed audio class)
USB audio controller
Audio class encoder/decoder
USB synchronization
Synchronous type (synchronize with 1ms SOF)
24-bit stereo A/D converter with mute control
查看全文
