NS DS90UR905Q-906Q 24位FPD串并-并串转换方案
关键词:汽车电子 汽车显示器 汽车音响
时间:2009-10-20 11:45:00       来源:NS, , ,
NS公司的DS90UR905Q/906Q芯片组是5-65MHz 24位彩色FPD-Link II串行化器和串并转换器,能把并行RGB视频接口转换成高速串行接口,在双绞线上传输,从而大大方便了系统设计.主要应用在汽车电子导航显示器和娱乐显示器.本文介绍了DS90UR905Q/906Q芯片组的主要特性,方框图以及典型的连接框图.
DS90UR905Q/DS90UR906Q:5 - 65 MHz 24-bit Color FPD-Link II Serializer and
Deserializer
The DS90UR905Q/906Q chipset translates a parallel RGB Video Interface into a high-speed serialized interface over a single pair. This serial bus scheme greatly eases system design by eliminating skew problems between clock and data, reduces the number of connector pins, reduces the interconnect size, weight, and cost, and overall eases PCB layout. In addition, internal DC balanced decoding is used to support AC-coupled interconnects.
The DS90UR905Q Ser (serializer) embeds the clock, balances the data payload, and level shifts the signals to highspeed low voltage differential signaling. Up to 24 inputs are serialized along with the three video control signals. This supports full 24-bit color or 18-bit color and 6 general purpose signals (e.g. Audio I2S) applications.
查看全文
