TI CC11x1-Q1超低功耗汽车电子应用方案
关键词:汽车电子 TPMS系统 防盗系统
时间:2009-10-19 10:40:00       来源:TI, , ,
TI 公司的CC11x1-Q1是1GHz以下的低功耗分数N UHF器件,适用于ISM频段的315 MHz, 433 MHz, 868 MHz和915 MHz,稍加编程还可用在310-MHz到348-MHz, 387-MHz 到464-MHz和779-MHz 到928-MHz频段. CC11x1-Q1集成了高度可配置的基带调制解调器,支持各种调制格式,数据速率高达250kBaud,灵敏度高达–114 dBm,输出功率高达+10 dBm,工作温度高度125度C,主要用在315/433/868/915-MHz ISM/SRD频段的超低功耗无线应用,汽车服务连接,车库门开启器,TPMS系统以及遥控无线进入系统.本文介绍了CC11x1-Q1主要特性,简化方框图, 典型的315MHz/433MHz和868MHz/915MHz应用电路以及应用电路材料清单.
Low-Power Sub-1-GHz Fractional-N UHF Device Family for Automotive
The CC11x1-Q1 device family is designed for very low-power wireless applications. The circuits are mainly intended for the Industrial, Scientific and Medical (ISM) and Short Range Device (SRD) frequency bands at 315 MHz, 433 MHz, 868 MHz, and 915 MHz, but can easily be programmed for operation at other frequencies in the 310-MHz to 348-MHz, 387-MHz to 464-MHz, and 779-MHz to 928-MHz bands.
查看全文
