Maxim公司的MAXQ7665A-MAXQ7665D 是基于MCU的智能系统级芯片(SoC)数据采集系统. MAXQ7665A- MAXQ7665D集成了高性能16位RISC核,带PGA的12位500ksps SAR ADC,支持数据速率高达1Mbps的CAN 2.0控制器.此外还集成了测量芯片温度的温度传感器和遥控温度传感器驱动器,多达128KB闪存和512B RAM以及多种外设接口.这些器件主要用在汽车转向传感器,基于CAN 和LIN的汽车传感器以及工业控制.本文介绍了MAXQ7665A- MAXQ7665D的主要特性,方框图和典型工作电路,以及MAXQ7665评估板的详细电路图和所用元件列表.
The MAXQ7665A–MAXQ7665D smart systems-on-a-chip (SoC) are data-acquisition systems based on a microcontroller (μC). As members of the MAXQ family of 16-bit, reduced instruction set computing (RISC) μCs, the MAXQ7665A–MAXQ7665D are ideal for low-cost, low-power, embedded applications such as automotive, industrial controls, and building automation. The flexible, modular architecture design used in these μCs allows development of targeted products for specific applications with minimal effort.
The MAXQ7665A–MAXQ7665D incorporate a high-performance 16-bit RISC core, a 12-bit 500ksps SAR ADC with a programmable gain amplifier (PGA), and a full CAN 2.0B controller supporting transfer rates up to 1Mbps. These devices include a 12-bit DAC with a buffered voltage output and on-chip oscillator circuitry to operate from an external high frequency (8MHz) crystal. There is also a ..
查看全文
