Power Integrations InnoSwitch3-AQ系列35W电源设计RER-913Q
关键词:电源管理DC/DC转换器SiC开关 Power IntegrationsInnoSwitch3-AQ
时间:2022-3-18 16:36:23      来源:中电网
Power Integrations公司的InnoSwitch3-AQ系列是CV/CC QR反激开关器集成电路,集成了用于汽车应用的750V,900V和1700V开关和FluxLink反馈. InnoSwitch3-AQ系列大大简化了汽车应用中隔热反激电源转换器的设计和制造.器件组合了初级和次级控制器以及安全的反馈,允许即使宽输入电压范围30VDC到>1000 VDC也具有精确的输出电压调整.器件具有多种保护特性,包括线路过压和欠压保护,输出过压和过流限制以及超温关断.
Power Integrations公司的InnoSwitch3-AQ系列是CV/CC QR反激开关器集成电路,集成了用于汽车应用的750V,900V和1700V开关和FluxLink反馈. InnoSwitch3-AQ系列大大简化了汽车应用中隔热反激电源转换器的设计和制造.器件组合了初级和次级控制器以及安全的反馈,允许即使宽输入电压范围30VDC到>1000 VDC也具有精确的输出电压调整.器件具有多种保护特性,包括线路过压和欠压保护,输出过压和过流限制以及超温关断.器件从30V起动,使它非常适合功能安全的关键应急电源.满负载时的效率高达90%,无负载输入功率小于15mW.输出过压和过流时具有自动重器的故障响应,精确的可编程输出过流阈值,可编程输入欠压值.器件具有AEC-Q100证书,加强隔离性per IEC60664-1,隔离电压大于5000 VRMS ,100%产品经过HIPOT测试, UL1577, TUV (EN62368-1), CQC (GB4943.1).主要用在汽车子系统的电源如牵引逆变器电源(EPS),高压到低压的DC到DC转换器(APM),电池管理系统和车载充电器.本文介绍了InnoSwitch3-AQ系列主要特性,初级和次级控制器框图,典型应用电路以及采用InnoSwitchTM3-AQ INN3947CQ 的35W隔离反激电源参考设计DER-913Q主要特性,电路图,材料清单和PCB设计图.
CV/CC QR Flyback Switcher IC with Integrated 750 V, 900 V and 1700 V Switch and FluxLink Feedback for Automotive Applications. The InnoSwitch™3-AQ family of ICs dramatically simplifies the design and manufacture of isolated flyback power converters in automotive applications. The InnoSwitch3-AQ family combines primary and secondary controllers and safety-rated feedback into a single IC allowing accurate output voltage regulation even with wide input voltage range of 30 VDC to >1000 VDC.
InnoSwitch3-AQ family devices incorporate multiple protection features including line over and undervoltage protection, output overvoltage and over-current limiting, and over-temperature shutdown. Device start-up from 30 V makes it ideal for functional safety critical emergency power supplies.
InnoSwitch3-AQ系列产品.亮点:
Highly Integrated, Compact Footprint
• Up to 90% efficiency across full load range
• Incorporates a multi-mode Quasi-Resonant (QR) / CCM...
