TI AM2732基于Arm Cortex-R5F和C66x浮点DSP核的MCU开发方案关键词:Arm Cortex-R5F MCU C66x浮点DSP核工厂自动化机器人 TI AM2732
时间:2022-3-17 16:02:18 来源:中电网
TI公司的AM273x系列是基Arm Cortex-R5F和C66x浮点DSP核的高度集成和高性能的微控制器(MCU).器件使原始设备制造商(OEM)和原始设计制造商(ODM)具有强健软件支持,丰富用户接口和高性能,通过全集成混合处理器解决方案的最大灵活性,从而快速把产品推向市场.该MCU集成了硬件安全模块(HSM)和内置安全功能,大容量集成的RAM和宽温度范围, AM273x系列提供了安全和成本效率解决方案,用于许多工业和汽车应用.
TI公司的AM273x系列是基Arm Cortex-R5F和C66x浮点DSP核的高度集成和高性能的微控制器(MCU).器件使原始设备制造商(OEM)和原始设计制造商(ODM)具有强健软件支持,丰富用户接口和高性能,通过全集成混合处理器解决方案的最大灵活性,从而快速把产品推向市场.该MCU集成了硬件安全模块(HSM)和内置安全功能,大容量集成的RAM和宽温度范围, AM273x系列提供了安全和成本效率解决方案,用于许多工业和汽车应用.双核Arm Cortex-R5F MCU子系统工作频率高达400MHz,双核Arm Cortex-R5F群支持双核和单核操作, TMS320C66x DSP核32位浮点DSP,工作频率450MHz(14.4 GMAC).器件的存储器子系统有高达5.0MB RAM(OCSRAM),存储器内存空间在DSP,MCU和共享L3间共享, 3.5625MB共享L3存储器,专用于主子系统的960KB以及专用于DSP子系统的384KB主要用在机器人,工厂自动化安全护卫,建筑物自动化,汽车音频,交通监视,机器视角,航空航天以及工业运输.本文介绍了AM2732主要特性,功能框图, 案例应用电路, 评估模块Sitara AM2732x系列EVM主要特性,电路图,材料清单,PCB设计图和装配图.
The AM273x family of microcontrollers is a highly-integrated, high-performance microcontroller based on the Arm Cortex-R5F and a C66x floating-point DSP cores. The device enables Original-Equipment Manufacturers (OEM) and Original-Design Manufacturers (ODM) to quickly bring to market devices with robust software support, rich user interfaces, and high performance, through the maximum flexibility of a fully integrated, mixed processor solution.
With an integrated Hardware Security Module (HSM) and functional safety support built in, large, integrated RAM on die and a wide temperature range, the AM273x offers a safe, secure and cost effective solution for many industrial and automotive applications.
The AM273x device is provided as part of a complete platform solution including hardware reference designs, software drivers, DSP library, sample software configurations/applications, API guide, and user documentation.
AM2732主要特性:
Processor Cores:
• Dual-core Arm® Cortex®-R5F MCU subsystem operating up to 400 MHz, highly-integrated f...
