关键词:Arm Cortex-M0+ CPU 家用电器 马达驱动 洗衣机 Infineon IKCM10H60GA
时间:2022-01-25 14:05:20 来源:中电网
Infineon公司的PSoC 4100S Plus是基于Arm® Cortex™-M0+ CP的可编程嵌入系统控制器,具有可升级和重新配置的平台架构,组合了可编程和配置模拟和数字区块以及灵活的自动路由,是PSoC 4平台架构的成员.它组合了有标准通信和计时外设的微控制器,最好性能的容性触摸感应系统(CapSense),可编通用连续时间和开关电容模拟区块,以及可编连接性. PSoC 4100S Plus器件向上和PSoC 4平台兼容,以满足新的应用和设计需求. PSoC 4100S Plus是32位MCU子系统, Arm Cortex-M0+ CPU工作频率48-MHz,多达128KB闪存,多达16KB SRAM和8路DMA引擎.而IKCM10H60GA是基于CIPOS™ Mini 600 V, 10 A三相TRENCHSTOP™ IGBT的智能功率模块.评估板REF-MHA1KIM5PSOC4是洗衣机马达驱动参考设计,它主要由PSoC 4100S Plus控制器和基于CIPOS™ Mini 600 V, 10 A三相TRENCHSTOP™ IGBT的智能功率模块IKCM10H60GA组成.本文介绍了PSoC 4100S Plus主要特性和框图, 评估板REF-MHA1KIM5PSOC4主要特性和主要优势与指标,框图,以及FOC控制系统特性和框图,电路图,材料清单和PCB设计图.
PSoC® 4 is a scalable and reconfigurable platform architecture for a family of programmable embedded system controllers with an Arm® Cortex™-M0+ CPU. It combines programmable and reconfigurable analog and digital blocks with flexible automatic routing.
PSoC 4100S Plus is a member of the PSoC 4 platform architecture. It is a combination of a microcontroller with standard communication and timing peripherals, a capacitive touch-sensing system (CapSense) with best-in-class performance, programmable
..分享到:
