TI公司的TPSM63603是高度集成功率模块,该3A功率解决方案在热增强的QFN封装内组合了36V输入,带功率MOSFET的降压DC/DC转换器,屏蔽电感器和无源元件.30引脚QFN封装具有增强的热性能,小占位尺寸,和低EMI.TPSM63603是紧凑的容易使用的功率模块,输入电压从3.0V到36V,输出电压范围从1.0V到16V.器件开关工作频率从200kHz到2.2MHz,频率同步,漏极开路的功率良好电路用于电源轨顺序排列和故障报告.单调的起动预偏压负载,精密使能用来可编程欠压锁住(UVLO),可自动恢复的热关断.具有业界最好的效率,FPWM模式工作,总输出电压精度1%,低IQ电流9-μA,工作环境温度–40C 到105C.满足CISPR22和CISPR32 B类发射要求,不需要外接回路补偿元件.主要用在测试和测量设备,工厂自动化和控制,航空和国防,通用电源.本文介绍了TPSM63603主要特性,功能框图和应用电路以及评估模块TPSM63603EVM主要特性,电路图,材料清单和PCB设计图.
The TPSM63603 power module is a highly integrated3-A power solution that combines a 36-V input,step-down DC/DC converter with power MOSFETs,a shielded inductor, and passives in a thermallyenhanced QFN package. The 30-pin QFN packagehas enhanced thermal performance, small footprint,and low EMI. The package footprint has all signal andpower pins accessible from the perimeter as well asfour larger thermal pads beneath the device for simplelayout and easy handling in manufacturing.
The TPSM63603 is a compact, easy-to-use powermodule with a wide output voltage range of 1.0 V to16 V. The module is designed to quickly and easilyimplement a power design in a small PCB footprint.
..分享到:
