关键词:ARM Cortex-M4 MCU 数字电源 工业控制 XMC4200
时间:2017-08-29 10:42:25 作者:Infineon 来源:中电网
Infineon公司的XMC4100/XMC4200是基于ARM Cortex-M4处理器核的工业应用微处理器(MCU),具有16位和32位Thumb2指令集,DSP/MAC指令,浮点单元,存储器保护单元,嵌套矢量中断控制器,集成了16KB引导ROM,多达16KB高速程序存储器,多达24KB高速数据存储器和多达256KB带1KB指令缓存的闪存,以及通信外设,模拟外设和工业控制外设,主要用在工业连接,工业控制,电源转换和检测和控制.本文介绍了XMC4100 / XMC4200 MCU主要特性,框图以及XMC4200数字电源控制板主要特性,硬件框图,电路图,材料清单和PCB元件布局图.
XMC4100/XMC4200 Microcontroller Series for Industrial Applications The XMC4[12]00 devices are members of the XMC4000 Family of microcontrollers based on the ARM Cortex-M4 processor core. The XMC4000 is a family of high performance and energy efficient microcontrollers optimized for Industrial Connectivity,Industrial Control, Power Conversion, Sense & Control.
XMC4100/XMC4200 MCU主要特性:
CPU Subsystem
• CPU Core
– High Performance 32-bit ARM Cortex-M4 CPU
– 16-bit and 32-bit Thumb2 instruction set
– DSP/MAC instructions
– System timer (SysTick) for Operating System support
• Floating Point Unit
• Memory Protection Unit
• Nested Vectored Interrupt Controller
• One General Purpose DMA with up-to 8 channels..
分享到:
