时间:2016-06-15 11:13:09 作者:Infineon 来源:中电网
Infineon公司的EconoPACK 4系列产品是从100A到多达400A的650 V和1200 VIGBT模块,具有极好的电连接性能,坚固耐用,容易使用,主要用于通用驱动器, 伺服驱动器,再生能源系统,不间断电源(UPS),空调器等.本文介绍了EconoPACK™ 4主要特性,评估板F3L2020E12-F-P_EVAL主要特性,电路图,材料清单和PCB元件布局图和设计图.
EconoPACK™ 4 features a screw power terminal, providing an excellent electrical connection. The DC and AC links are separated and distinguishable at a glance for ease of use. Control pins feature our PressFIT technology for solderless assembly. A new and highly reliable ultrasonic welding process is used for all connections between theterminals and the DCBs within the module.
Optimized gate driver connection is possible by placing the driver on top of the module. Low parasitic stray inductance and optimized thermal resistance to heat sink support to excellent inverter solutions.
The EconoPACK™ 4 portfolio is available in current ratings from 100 A up to 400 A. 6-pack and half-controlled input rectifier configurations (available in 1600 V with current ratings of 240 A and 360 A) are tailor-made for industrial applications.
分享到:
