关键词:工业控制 马达驱动 智能功率模块(IPM) STGIPS20C60
时间:2016-03-08 09:42:58 作者:ST 来源:中电网
ST公司的STGIPS20C60是小型低损耗智能功率模块(IPM),三相20A 600V IGBT桥,包括用于栅极驱动的控制IC和续流二极管(FWD),主要用在三相马达驱动和空调机.本文介绍了STGIPS20C60主要特性,框图和典型应用电路,以及STEVAL-IHM034V2 1300W马达控制板主要特性,电路图和材料清单.
SLLIMM™ small low-loss intelligent molded moduleIPM, 3-phase inverter - 20 A, 600 V short-circuit rugged IGBT. This intelligent power module provides acompact, high performance AC motor drive in asimple, rugged design. Combining ST proprietarycontrol ICs with the most advanced short-circuitruggedIGBT system technology, this device is ideal for 3-phase inverters in applications such asmotor drives and air conditioners. SLLIMM™ is atrademark of STMicroelectronics
STGIPS20C60主要特性:
IPM 20 A, 600 V 3-phase IGBT inverter bridgeincluding control ICs for gate driving and freewheelingdiodes
Short-circuit rugged IGBTs
3.3 V, 5 V, 15 V CMOS/TTL inputscomparators with hysteresis and pull down /pull up resistors
Undervoltage lockout
Internal bootstrap diode
Interlocking function
Smart shutdown function
Comparator for fault protection against overtemperature and overcurrent
DBC leading to low thermal resistance
Isolation rating of 2500 Vrms/min..
分享到:
