关键词:ARM Cortex-M7 MCU 无线通信 运动识别 马达控制
时间:2016-01-29 10:52:24 作者:ST 来源:中电网
ST公司的STM32F756xx系列是基于高性能ARM®Cortex®-M7内核的32位RISC MCU,工作频率高达216MHz,具有单浮点单元(SFPU)精度,支持所有的ARM单精度数据处理指令和数据类型.集成了高达1MB闪存,320KB SRAM,16KB TCM RAM,4KB备份SRAM,满足高速或多通道音视频,无线通信,运动识别或电机控制的需求.本文介绍了STM32F756xx系列主要特性,框图,以及评估板STM32756G-EVAL主要特性,框图,电路图和材料清单.
The STM32F756xx devices are based on the high-performance ARM®Cortex®-M7 32-bit RISC core operating at up to 216 MHz frequency. The Cortex®-M7 core features a single floating point unit (SFPU) precision which supports all ARM®single-precision data-processing instructions and data types. It also implements a full set of DSP instructions and a memory protection unit (MPU) which enhances the application security.
分享到:
